Help w/426f Clutch
2 replies to this topic
  • 7xmoto
Posted August 17, 2005 - 01:16 PM
have a 2000 YZ426f and the clutch jerks (doesn't engage smoothly) badly when I try to take off. It's the original clutch so I need to replace it. Can the pressure plate be warped?
thx
:D
  • bigdrtrdr
Posted August 17, 2005 - 06:12 PM
Most likley the clutch basket is toast. Grooves/knotches get worn into the fingers of the basket causing the jerky engagement.
By a new Barnett clutch kit and one of there new baskets with the steel sleeved fingers. "Way cheaper than a Hinson unit" and you should be good to go.
Eric
  • TeamScream
Posted August 27, 2005 - 09:50 PM
Eric
And while you are in there, do yourself a favor and inspect the kickstart return stop CAREFULLY, if it is buggered at all, replace it along with BOTH of the bolts that secure it into place, there are 4 parts total including the bolts that you need, $14.00 total and will save your cases in the event of a lazy kick/backfire.
Trust me.
