Cam Timing Help Needed
3 replies to this topic
  • moto9
Posted August 15, 2005 - 10:12 PM
Does any one know the trick to setting the cam timing.
I had to replace a broken connecting rod and need a little help setting the timing on the cams.
Thanks
  • djo269
Posted August 15, 2005 - 11:04 PM
The lobes should face outward/opposite to each other. In otherwords, the punch marks on the cam sprockets should be visible on the top edge and vertical from a side view of the engine. Also the mark "I" should line up on the rotor in the hole. The timing chain is easier to install when you put it on the exhaust sprocket first. Take your time on it. Hope this helped...
Posted August 16, 2005 - 07:57 AM
What engine? Stock cams or aftermarket? Using a 450 cam in a 426? A few details are needed.
  • moto9
Posted August 16, 2005 - 03:34 PM
Thanks for the help, I got it.
  • Hot  47 replies
  • Hot  36 replies
  • Hot  28 replies
  • Hot  38 replies
