Edlebrock question
4 replies to this topic
  • honkylips
Posted August 14, 2005 - 04:13 PM
How do you adjust idle speed? I thought it was by the black knob that's on the end of the tube, but that thing only seems to turn counterclockwise?
  • BWB63
Posted August 14, 2005 - 05:16 PM
That is it. It should turn both ways. It might be installed wrong or in a bind.
  • frankstr
Posted August 14, 2005 - 05:47 PM
Counterclockwise will only turn the idle down,it should turn clockwise also to turn up the idle.........
  • BigMikey
Posted August 15, 2005 - 11:36 AM
It's been a while, but I seem to remember there is a small nut on the end of the black tube that must be removed for it to work properly.
When I adjust mine, I usually end up holding the black tube about half way up with my left hand and turning the knob with my right. If I don't, the tube twists resulting in a bind.
Hope this helps.
  • bork
Posted August 17, 2005 - 08:24 PM
To increase idle, I twist my grip and turn black knob , so it takes pressure off stop . (no binding)
