DRZ400S seal behind front sprocket replacement
12 replies to this topic
  • bigskyrider
Posted August 13, 2005 - 06:33 PM
Wondering if anyone has experienced this seal failing. Mine just did after 700 miles of riding(both street and single track). I have an 04 and little mechanical experience with this bike. Is it possible to replace the seal once the sprocket is off or is it more labor intensive?
Thanks for your input
  • Erik Marquez
Posted August 13, 2005 - 06:38 PM
Yes,, common deal.. Is the counter shaft nut loose? (the one holding the sprocket on) Do a search,, you will find a lot of info,, Read some of it and fell free to come on in and ask questions.
  • Neil Claydon
Posted August 13, 2005 - 06:44 PM
There is an improved spacer and oilseal set available from several sources,E-Bay etc.
Or try "search this forum" better still I'll do it for you.
http://www.thumperta...searchid=589850
Neil. :D
  • bigskyrider
Posted August 13, 2005 - 06:52 PM
Thanks for the doing the work for me, I will work the archives
  • Erik Marquez
Posted August 13, 2005 - 08:43 PM
Neil. :D
I've seen a stainless steel spacer for sale,, .. not sure that qualifies as "improved" :D
What "improved" seal are you referring to?
  • kawidual
Posted August 14, 2005 - 12:49 AM
Replaced mine when it failed around 10000 miles, 20000 miles later no issues.
Used the oem replacement parts and red loctite after every sprocket swap.
That suckers is not coming off. Its a fairly easy/quick job.
There is a post with all the part numbers you need floating around.
Try a search for CS nut, etc. www.ronayers.com has a fiche to get them from also.
  • thumper929
Posted August 14, 2005 - 02:01 AM
ive repleaced mine with a high grade stainless item
  • Neil Claydon
Posted August 14, 2005 - 03:13 AM
Sorry Bronco,
I meant "improved" as in a better quality spacer. i.e. harder steel, and better quality of machining. It also came with a twin lip oil seal.
The harder piece of steel is probably the most important bit, I fitted these parts at 3500 miles and the old spacer was already grooved.
I also fitted front and rear wheel spacers from the same source a few days ago, and found that at 5000 miles all three of the original spacers had the start of a groove worn in them, the front was worst, bad enough that I changed the seal as well.
Neil.
:D
  • thumper929
Posted August 14, 2005 - 03:16 AM
Sorry Bronco,
Neil.
:D
sounds like the same source i got mine off ,very good quality
i will get the wheel spacers too!!!!!
  • 2wheels-drz
Posted August 14, 2005 - 04:21 AM
it can be hard to get the old seal out when replacing, i screwed 4 small wood screws into the old seal and pull it out that way.:D .better than messing around with a screwdriver,,,once done go and :D
  • thumper929
Posted August 14, 2005 - 04:32 AM
my suzi dealer fitted mine during the first service :D
:eek:
  • Spud786
Posted August 14, 2005 - 12:34 PM
I think, because I've had no issue its certain areas of the country which have corrosive mud. I rode Florida sand and never washed the bike and that seal has about 20,000 miles on it, the 1 st one had about 14,000 miles when I replaced out of fear reading here, but it was in excellent shape along with the spacer.
I've got a brand new spacer and seal, I may replace at the CS sprocket change, another 10,000 miles.
  • magnetoboy
Posted September 13, 2005 - 05:18 PM
I was reading some of the info about the counter shaft seal leaking and was wondering if the seal is leaking, will it leak only while the engine is running, or will it continue to leak after the engine is turned off?
2003 Drz400s struggling at 55 mph? by kingbluey
  • Hot  65 replies
Drz400s petcock question by JEEPNICK
  • Hot  27 replies
Suzuki DR-Z400SM 2017 by Chris.GVS
  • Last review by MidnightMotard
  • On December 29, 2016
Found Dr-Z400 12 years old "Factory PACKED" by ezkhan
  • Hot  28 replies
Upgrading from S to SM forks and rear axle worth it? by arpuS
  • Hot  50 replies
