How far from stock are you?
16 replies to this topic
  • Ramcc4x4
Posted August 13, 2005 - 03:23 PM
I was looking at my bike and thinking of all the extra $$$ I have done. I haven't sprung for the big bore kit yet, but the mods have definately added up. If you are bored please list mods to your BRP and maybe best/worst mods also.
2002 XR650R,White Bros header, White Bros "E" Series exhaust w/12 discs & Quiet Core insert,XR'S Only CDI,high pressure thermostat,55W headlight,headlight guard,UNI air filter,cut & screened side panel, Edelbrock Qwiksilver (#21 needle,20 clicks,1/4 from full acc. pump),Moose skidplate,Clarke 4.3 gallon tank (red w/factory tank graphics),Pro Taper big bars,aftermarket grips,Moose handguards,rear rotor guard,rear caliper guard,rear led light,Moose tall seat,IMS footpegs,smog blockoff kit,Trailtech speedo,120/100/18 rear tire,13/48 gearing,DID chain,Moose rear fender pack,Moose front shroud bag for desert rides,probably more I just can't think of it right now.
Best mod (performance): pumper carb
worst mod: not making the bike CA street legal when I had the chance
Best comfort mod: Moose tall seat for day long riding
  • big t
Posted August 13, 2005 - 03:35 PM
Pro Tapers w/ universal adapters, Edelbrock carb, Xr's only skid plate, and the usual uncorking mods. That's it.
  • frankstr
Posted August 13, 2005 - 04:55 PM
Best mod, Edelbrock carb........ :D
rest of my mods are listed in my garage..... :D
  • wr450fyamaha
Posted August 13, 2005 - 06:30 PM
best mod..........yoshimura exhaust.....rest in garage.
  • BWB63
Posted August 14, 2005 - 07:45 PM
[COLOR=DarkRed]680cc wisco 11:1 piston, Barnums Pro cam, Corillo Rod, Kimberwhite valve springs & S/S valves w/ 3mm oversized intake[/COLOR], [COLOR=Red]Edelbrock bored to 42mmX40mm, 18 needle 10 clicks out, Clarke 4.3 tank, UNI air filter, Holes in air filter cover, No back fire screen,[/COLOR] [COLOR=Purple]Moriwaki Full Exhaust[/COLOR], [COLOR=DeepSkyBlue]Eibach 45kg Fork springs w/re-shimmed & Re-valved, 110mm 2.5wt ultra light Golden Spectro SPL Fork Fluid, Eibach 10kg shock springs, (90mm preload) 200psi nitrogen, US-1 RaceTech shock oil, re-shimmed & Outerwears Shock Sock,[/COLOR] [COLOR=Blue]Galfer Steel Braided Brake Lines (red) and brake pads, Titex rotors,[/COLOR] [COLOR=RoyalBlue]Scott's steering dampener, Applied triple clamp, SuperBrace fork brace, Renthal RC Fatty Bars, Oil sight tube, Acerbis; Pro-Handguards, head light, LED Tail Light, Fender w/ fender brace & front rotor cover, XR's Only's, Chain Guard, case saver & skid plate, BajaDesigns Shark Fin, IMS Fluidyne Radiators & Pro foot pegs, Spyder Grips, Ceet seat cover, LED tail/brake light, Re-wound duel stage stator & stator case vent tube,[/COLOR] [COLOR=Green]15cs & 49 or 47 IronMan sprocket, X-ring EVR2 Gold chain,[/COLOR] [COLOR=Magenta]Black Excel rims, Red Rad hubs and heavy duty spokes, 115 [/COLOR] [COLOR=Orange]NAPA Thermostat, Evens Coolent,[/COLOR]
I would like to go to 280mm front floating rotor.
http://xr650r.borynack.com
http://borynack.com/xr650r.htm
  • raven-9
Posted August 15, 2005 - 04:46 AM
94- xr 600, 630 bore kit 42mm flatslide mikuni carb, full exaust from the headers cr 500 back suspension, cr 500 front upside down forks, oversized disk on front, all ktm black guards, exel black rims, ufo black twin black headlights, tag bars,....alot more
sold the bike 2 days ago to a mate(keep it in the family)
now on a 06 ktm 525 exc.....awesome bike!!
  • dvo1
Posted August 15, 2005 - 06:08 AM
Ohlins rear shock w/ Ti. spring, Ohlins Fork and steering damper, Akrapovic full exhaust system, Aluminum gas tank, Kehihn FCR 41mm carb, Custom air intake, Full HRC engine power-up kit, Answer pro taper bar, Emig triple clamps for invert fork conversion, Acerbis supermoto front fender, Acerbis Cyclops headlight, IMS pro series foot pegs, CRF reservoir less rear master cylinder, SDG seat, 1.8 rad cap Powder coated frame, Full titanium hardware, Marchesini wheels, Thumb decompression lever by gyt-r, , SRC case saver, Aluminum chain guard, Brembo front brake and caliper, Stainless brake lines Some other stuff but I can't remember.
Dan V.
  • Supplicate
Posted August 15, 2005 - 08:31 AM
[COLOR=Magenta]Gold Excel rims, Red Rad hubs and spokes[/COLOR]
where did you get your hubs?
I've been trying to find a good source for quality hubs for the BRP, the local dealership is having one hell of a time finding them.
as for the mods:
Eibach springs front and rear, new skid plate/disk guard/chain guide. Devol Eng. radiator guards, Barnum's Exhaust, IMS tank, I think thats it thats installed ATM.
upcoming:
BRP top and bottom tripple clamps, 'SUB' mount, steering damper, oversized handelbars, spider grips, suspension revalve, I think thats it in the planning stages for now.
  • bork
Posted August 15, 2005 - 10:08 AM
dvo1 , You quote a alum gas tank . Where is that from ? How many gal and $. Make shift fit or factory fit ??
Raven's bike sounded like a pretty good set up .
  • thumperswede
Posted August 15, 2005 - 10:35 AM
Not far enough! only have 320-disc and moto wheels. need(?) carb, air intake mods, exhaust
  • BWB63
Posted August 15, 2005 - 11:00 AM
as for the mods:
upcoming:
[COLOR=Blue]Click Here ->[/COLOR] [COLOR=DarkRed]Rad Hubs[/COLOR]
  • SONODROOPY
Posted August 15, 2005 - 11:25 AM
95 XR600R - Snorkel out, K&N filter, Jetted, Header, Husky 96db exhaust (sounds great) :D . Thumps at low RPM, flappy WOT, and sounds like a big rig when decelerating (sweet). Maxxis IT's, 13t up front.
  • Supplicate
Posted August 15, 2005 - 03:45 PM
:D :D :D :eek: :eek:
:eek: :D :D :D
  • BWB63
Posted August 15, 2005 - 03:56 PM
Rad also has EAGLE Hubs complete wheel setups for $870 for both front and back! That is cheap and they have a 100% warranty, even if it is your fault they replace them for the first year. No question asked just new rims!
  • Supplicate
Posted August 15, 2005 - 04:43 PM
I noticed that, blew me away.
I really liked there HEX setup for only a little more money.
Which do you have, the HEX or the Eagle hubs?
  • BWB63
Posted August 15, 2005 - 05:29 PM
I have the Red Hexed Rad Hubs w/ Black Excel back rim and egle front rim. I liked the idea of the warenty on the eagle rim. I bent my gold Excel rims in a bad crash last year, that is why I went Black.
  • wr450fyamaha
Posted August 15, 2005 - 06:07 PM
dare i say it? to far.
  • 17 replies
  • 9 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
Washington
  • Hot  32 replies
  • 4 replies
