trail tech
7 replies to this topic
  • djbiker
Posted August 13, 2005 - 11:09 AM
i just bought a trail tech computer and installed it using the extra magnet glued in one of the holes on the rotor because i couldn't get my rotor bolts loose imput my wheel size as 2133mm fowlling the steps and it says im doing 53 3rd gear half throdle, what did i do worng
  • 02YZ426
Posted August 13, 2005 - 12:06 PM
Are you sure you measurments are correct? Is your speedometer set to bike #1 or bike #2? Maybe you have the computer is to the wrong bike in the setup.
  • djbiker
Posted August 14, 2005 - 07:43 AM
no its bike number one and checked the math
  • motodave289
Posted August 14, 2005 - 09:36 AM
Measurement sounds right. I think it sayed in mounting sender that magnet
should pass at top or bottom of sender if it passes in middle will show double
your speed.As for rotor bolt a little heat from propane torch on hub will loosen
up locktight to get bolt out.
  • djbiker
Posted August 15, 2005 - 04:15 AM
rotor bolt is so tight that it just shredded my Allen wenches, i'll try to heat it up
i mounted my sender right where it said to and looks just like in the pictures
  • 93gt
Posted August 20, 2005 - 01:31 PM
I just got done installing mine today and it seems to be working great! I had no issues with the rotor bolt, but a little heat usually helps that stubborn locktight. I will double check the mph next to a GPS to see how close it is. I think its on the money though! Also, I came up with 2114 for the wheel size measurement. I measured 26.5 inches and converted etc.. I seem to be a bit off compared to 2133 though. Could I be that far off?
  • palmdaleRider
Posted August 20, 2005 - 04:17 PM
No Trial Tech, but I did have to swap the rotor the other day. No heat required, nothing stripped or rounded. Allens are a pain, unless you have the proper size and then you must still use care. Instead of Metric, did you use an American Std Allen? Also good to have a set of Allens on 3/8 rachet mounts. My 2c's...
  • 93gt
Posted August 20, 2005 - 06:12 PM
I believe I used a 6mm allen. As cheap as they are, get yourself a set, or else you will be having a horrible time doing alot of little things!
