426 rod on a 400? maybe a 441 bore kit?
2 replies to this topic
  • R_Little
Posted August 12, 2005 - 06:49 AM
I tore down my 00 wr400 and found a slightly scored rod and a bad counterbalancer key.
I want to rebuild it with a big bore and auto-d cam. I want to go with a 426 rod.
Have 2 questions can I bore a 400 cylinder 95 mm for use with a 426 piston,rod and pin or must I buy a 426 cylinder?
2nd question, who can I use to rebuild the bottom end and crank on a fairly quick basis. Eric Gore is unreachable.
  • Pincushion
Posted August 12, 2005 - 12:52 PM
Check out this thread
SXP is a local riding buddy and knows his stuff. PM him if you have more specific questions. I'm hoping to have a Lukes Racing 444 ride report this weekend, as long as the final assembly goes without incident. I'll let you know what I think if you're interested.
  • Matt96xr6
Posted August 12, 2005 - 09:09 PM
The bottom end bearing is different sized if I remember correctly. THus you need a whole 426 crank then you need to see if the main bearings are the same size.
  • 0 replies
  • 9 replies
  • Hot  36 replies
  • Hot  28 replies
yz400f throttle bog by yz400fmaniac
  • Hot  28 replies
