Oil drain bolt
6 replies to this topic
  • TBone_Boston
Posted August 11, 2005 - 11:58 AM
Is this the right drain bolt?
I'm at my first oil change on my new '05 450. The manual (page 3-23) lists the 6 different drain bolts you need to remove. I can easily find all of them except for #3 "Drain Bolt (with gasket)".
Am I correct in assuming this is the bolt on frame (right above where the stock glide plate ends)? It is painted blue and looks like the diagram but I wanted to check.
Do any of you have a pattern of when you change the oil? (every ride? after a certain amoun of miles?) Do you change the filter each time?
  • jamieyz426f01
Posted August 11, 2005 - 12:04 PM
the blue bolt on the frame is the frame drain bolt, hold a container right over the hole though 'cus otherwise the oil will shoot out all over your tire and floor etc. :D
  • TBone_Boston
Posted August 11, 2005 - 12:25 PM
Great - so it looks like that is the missing piece. Thanks.
  • ISBB
Posted August 11, 2005 - 03:06 PM
ISBB usually drains at the frame and the crank case... 2 bolts done...
  • jamieyz426f01
Posted August 11, 2005 - 03:23 PM
ditto :D
  • black_n_blue_thumper
Posted August 11, 2005 - 09:00 PM
Every other or every third, I will drain all of mine. Otherwise I do like ISBB. Quick and easy and get 99% of the oil out. :D
  • TBone_Boston
Posted August 12, 2005 - 08:59 AM
awesome - thanks!
I had done a few small rides (30min) and a couple biggies (2 -3 hours) totaling 60 miles and the oild looked terrible. I think I'll do it every 5 hours or so.
thx
