headpipe's glow, but...
6 replies to this topic
  • 800screws
Posted August 09, 2005 - 06:07 PM
when i put on a fmf titanium 4 silencer and up'd the main to a 170, when it idles, it turns molten red! i put the stock back on and nothing. fmf recommends that the fuel screw be turned out 2.5 turns...would that help the glowing?
also would mis-shimmed valves make a ticking noise when it's running?
  • 642MX
Posted August 09, 2005 - 06:22 PM
Didn't we just go over all this?? :D
Headers glow....It's a fact. My factory header glows.
2.5 turns out would be richer than the stock setting, so yes, it could help cool the engine a little better. It is however, impossible to tell you that 2.5 turns out is the perfect set-up.......maybe 2 turns out will make your bike snappier?? Thats why you need an adjustable fuel screw (like a MSR) then you can make changes while the bikes running.
Loose valves make a ticking sound, you have checked them?......Right?... You really should not worry about jetting issues until you have your valves properly set. :D
  • XR650LSMGSGP
Posted August 09, 2005 - 06:26 PM
i was told by JD that its common for the header pipe to glows when rev hard on standstill.
Posted August 09, 2005 - 07:29 PM
Was it like THIS?
(from Wrooster's "collection" - used without permission)
  • storm 800
Posted August 09, 2005 - 08:38 PM
What the HELL was that? :D
  • ovrrdrive
Posted August 10, 2005 - 12:44 AM
I would say definitely adjust the fuel screw out and see if that helps. If you get past 3 turns out, go up one size on the pilot jet.
Glowing orange is normal, molten red is not.
  • 800screws
Posted August 10, 2005 - 02:52 AM
thanks for the info
