Head pooched?
3 replies to this topic
  • fowler175
Posted August 08, 2005 - 01:20 PM
Well, I found out what was causing my 450 to lock up. It turns out that for some reason my intake cam wasn't getting enough oil, and siezing on the journals (this time it locked up hard and jumped out of time!). Not sure why, as there is plenty getting to the exhaust, and the passages don't seem to be plugged. Maybe a weak oil pump? Anyways the journals on the head are damaged enough that the edges are furled over and I can't even remove the buckets! Am I stuck with buying a new head, or can I maybe get it built up and machined back to spec? The cam surfaces are still within spec and smooth, but look very dull. Is there a hard surface that maybe got removed? :D
I really like this bike for the 5 minutes thet I have actually gotten to ride it!!
Hopefully this is the last probs I have with it or it's down the road and back to Suzi!!
  • MotoGoalie
Posted August 08, 2005 - 01:26 PM
Did you recently reshim or have the cams out for any reason? Who did the work?
Perhaps they weren't torqued down properly?
  • fowler175
Posted August 08, 2005 - 01:42 PM
I recently took the cams out to change the head gasket. I bought a new torque-wrench (couldn't find a 1/4", so had to get a 3/8" 5-80lb), but it felt a little inconsistent. Think that would cause it? BTW, anyone know where to get a good deal on a new/used head. It's an 04 yzf450. I checked ebay, but no luck.
  • sharpmarble
Posted August 08, 2005 - 02:25 PM
I'm in the same boat as you, previous owner torqued the caps too tight. I had to scrape out the mushroomed aluminum with a screwdriver and then Dremel it all smooth. It runs, but I don't know for how long.....
The cheapest new head I could find was through www.crotchrocket.com
Good luck.
  • Hot  36 replies
Motocross
  • Hot  491 replies
  • Hot  28 replies
