neutral indicator light to a 02 wr426
6 replies to this topic
  • byggd
Posted August 08, 2005 - 12:07 PM
Has anyone added a neutral indicator light to a 02 wr426? I have a rekluse auto clutch so it's hard to tell when it's in neutral. I've read a couple threads on disconnecting the wire from the neutral switch to get full power to the coil when in neutral. Can I use that wire if I disconnect it?
  • 2000yzf426
Posted August 08, 2005 - 06:08 PM
I installed one on my 426 just bought a .99 cent led from radio shack and used 3m wire connectors to splice into the wires and left everything hooked up works great.
  • byggd
Posted August 09, 2005 - 04:52 AM
Did you use the light blue wire that comes from the neutral SW? If so does it send a + OR - signal?
  • byggd
Posted August 10, 2005 - 06:37 AM
Bump :D
  • rich-tenerife
Posted August 10, 2005 - 03:31 PM
Hello All
Can't add any thing to the blog and i guess i should search , but it's on topic .
I drive a WR 426 F 2002 . I Fitted the speedo and out curiosity and attension to detail .
I would like to know the wiring set up for the neutral and back light .
p.s. BYGGD what's the rekluse auto clutch ? It's more than a slipper clutch ?
:D
  • byggd
Posted August 11, 2005 - 06:05 AM
I'm not familiar with a slipper clutch but I have a feeling it's the same thing. Here is a statement from the Rekluse website. If you haven't yet check out their Website I have also called them a couple times and they are very helpful. It's nice to talk to someone who actually knows and uses the product rather than just a answering service giving caned answers.
The z-Start is a revolutionary new automatic clutch that replaces your stock pressure plate. The z-Start installs in minutes without modifying any of your existing clutch parts. From new trail riders to professional motocrossers, every motorcyclist can benefit from the z-Start. Browse this website to find out more.
Oh and if you purchase one, support the TT community and buy it here (if they ship overseas) :D
  • 2000yzf426
Posted August 11, 2005 - 05:40 PM
sorry i took so long to reply been busy moving, anyways i did use the light blue wire from the neutral switch i cant remember if its + or - but i think its + and i just grounded it off the ground wire in the harness, ill take a look this week end and get back to you( bike is an hour away right now) if you haven't figured it out allready.
