AIS and Radiator/Reservoir
4 replies to this topic
  • cgrlvr35
Posted August 07, 2005 - 06:46 PM
Hey all. Just finished with the GYTR AIS kit. What a difference it made. No pop any more. I have more poop to the bike. Also took the air snorkle out. I was going to cut out the holes on the right side. Ill wait.
My radiator question ???. I notice on the o5 yz450 there is no reservoir tank on the rear. I wanted to put a rear fender on and get rid of the rear light while I race. Can the 05 WR be changed like th eyz and get rid of the extra storage. Would you just plug the cap? Let me know. :D
  • Matty05
Posted August 07, 2005 - 07:14 PM
If you want to remove the reservoir tank, run the hose down to the ground with the carb hoses.
I have got a YZ rear guard on mine, you still have to cut holes in the side where the brackets are. It doesn't take long at all and I think Acerbis makes a YZ guard for the WR with the holes in it already. Don't get an original one as the plastic is crap.
  • cgrlvr35
Posted August 07, 2005 - 09:32 PM
Thanks Matty05. Ill look into it.
  • hotthrottle613
Posted August 08, 2005 - 06:16 AM
If you get rid of the overflow, it is recommended that you change the radiator cap to a 1.6 (found this info at www.bajadesigns.com when looking at adding side fuel tank.)
  • Joe Reitman
Posted August 08, 2005 - 07:24 PM
I was told today that KX500 cap is 1.6, may be readiLy available. Am considering the same setup, and run NPG-R. I have had good luck with NPG+ in a high compression 383 stroker Chevy engine.
