So Much For My Three Days Of Fun
1 reply to this topic
  • VOODOOCHILD
Posted August 05, 2005 - 08:01 PM
I recently got my 98' YZ400F put together after about a year of working on it. I went out to start it up today and could not kick it over after about the third attempt. Thought maybe it was my decompression cable. Long story short, I tore the whole motor apart again to find that I had slightly bent the two intake valves on the outsides. My question: is there a difference between pistons for a YZ and WR or is there possibly a difference in the OD of the valves themselves? I used a 2000 WR head in place of the 1998 YZ head with a new YZ piston. Did I over look something? I know for a fact that I had the valve clearance set to the manuals specs. The manual doesn't call out any differences in the valve clearance specs for those two different years. Any help would be wonderful. Any suggestions about what to replace would be helpful too. Thanks. :D
  • biznet1
Posted August 06, 2005 - 05:25 AM
I definately not the one that can give good technical advise about this, but are you sure that the timing is correct? You probably already know that if the timing is off, you can bend valves. I think the WR and YZ cams are different which means the timing is different. I'm suprised one of the experts (Gray or Cowboy) hasn't posted on this yet, but I'm sure they will soon.
  • On January 15, 2017
Motocross
  • Hot  491 replies
  • 0 replies
