Hard starting hot
not sure about the jetting, stock i think, free mods, sea level.
If he has done all of the free mods then I would try jetting first. If he has opened up both ends, intake and exhaust then he will most likely be a little lean. Hope this helps.
Josh
I have a similar problem, all jetted with a JD kit, runs great. After changing from a 65 to 70 starter jet the cold starting with choke on was WAY better. However, I believe (and someone please correct me if I'm wrong) the starter jet affects only the choke circuit, so it would only improve starting with the choke on. As far as hot starting, try the pilot jet and also increasing your idle a bit (I have yet to do this, but it's my next step). The hot start should work, but it hasn't helped much for me so I'm going after the pilot and idle. I also agree with SC; if you're jetting is stock you'll have to increase the main too.
