I have 426 Hot Cam question ??
4 replies to this topic
  • 426ing-in-MD
Posted August 04, 2005 - 03:57 AM
I have a '01 YZ 426F and I also have new auto-decomp Hot Cam I would like to install. I would like to ask you members for the links or previous threads on here that give a detailed run thru on putting the cam in my bike. I have seen them before but can't seem to find them now ??
Much appreciation in advance. :D
  • biznet1
Posted August 04, 2005 - 04:35 AM
This is for the 450 cam mod, but technically shouldn't be any different (although I'm not sure). Search for Grayracer posts, He is very knowledgeable and I believe he's provided some good input on this subject.
http://www.photonrac.../PDF/450cam.pdf
Posted August 04, 2005 - 07:18 AM
Keep in mind that if this is a Hot Cams part that was made for the 426, you will NOT use the timing method described for installing 450 cams into your engine. Follow the instructions that come with the cam. You should end up using the marks on the cam in a manner similar to the way the stock one times.
But if it's a Hot Cams for a 450, you will need to time the intake first, and then use it as a reference to set up the exhaust, as described in the 450 cam mod threads.
  • 426ing-in-MD
Posted August 04, 2005 - 05:10 PM
Thanks, it's a HotCam for the 426 and thats what I have !!
  • Satch0922
Posted August 04, 2005 - 05:17 PM
yeah....disregard the 450 cam mod PDF.....that is for using a 450 cam in the 426..
  • Hot  38 replies
  • Hot  47 replies
  • 10 replies
1998 yz400f will not idle. by trolley
  • Hot  32 replies
