Blown Engine?? Need help
2 replies to this topic
  • agr
Posted August 04, 2005 - 02:43 AM
Hi guys,
I just bought a WR450 '04 took her out for a spin and the decomp plug blew out. I noticed it immediately and stopped. I fixed that (checked the oil) and later went for another ride, after about 60 miles I heard a strange sound and then "pop" the engine shuts down. Now the kickstarter doesn´t move but the rear wheel isn´t stuck.
Any ideas what the problem might be??? And what I could do???
  • gregwr450f
Posted August 04, 2005 - 02:54 AM
I have no idea, but hang around for a while and someone will come up with an answer........Indy, calling Indy.
  • StreetbikePimp
Posted August 04, 2005 - 09:52 AM
Take the plastic plug off of the left side of your motor and you'll see a 17 mm nut on the end of the shaft. Put a socket wrench on there and see if you can turn the motor over.
If not, then something crashed.
