Will a 16 Tooth fit on a 650L
14 replies to this topic
  • sportbiker929
Posted August 01, 2005 - 07:31 PM
I need to raise the ratio a bit. Will it fit?
  • wr450fyamaha
Posted August 02, 2005 - 06:01 AM
try it or ask a dealer.
  • roadcam
Posted August 02, 2005 - 07:34 AM
looks pretty tight, I would have my doubts .. :D
  • BLOCKHEAD100
Posted August 02, 2005 - 08:14 AM
I just put on a 16-tooth sprocket. It's not cush-drive (maybe its for an XR600R?). It's a tight fit, but it does fit.
  • jamesp
Posted August 02, 2005 - 09:13 AM
None of them come with cush drive.
  • roadcam
Posted August 02, 2005 - 02:24 PM
my stock 15-tooth sprocket has some sort of rubber insert ... must be a cush-drive, of a sort Ive never seen before .. :D
  • XR650L_Dave
Posted August 03, 2005 - 08:23 AM
Its not an insert, really, its a little rubber bonded to the sprocket to help quiet the noise of the chain- I think.
It might cushion things a tiny bit if it actually holds the chain rollers off the bottoms of the sprockets, but not by much.
Dave
  • jamesp
Posted August 03, 2005 - 11:31 AM
Dave is right, it is simply for noise reduction. I doesn't reduce the load or wear on the sprocket/chain/countershaft whatsoever.
  • roadcam
Posted August 03, 2005 - 03:35 PM
OK, thanks, I was trying to figure out what the heck it was ... duhhh, .. once again, modern technology jumps up to bite me in the butt :D
  • XR650L_Dave
Posted August 04, 2005 - 08:34 AM
Modern technology? Thought you were talking about an XRL...
D
  • roadcam
Posted August 04, 2005 - 09:22 AM
:D my last few bikes were chopped HD panheads and flatheads ... think the jump to Honda XRL wasn't a major culture shock ??? ......... :D
  • crmc33
Posted August 07, 2005 - 04:37 AM
Id be very interested in your findings regarding the 16T.
I need higher gearing and would definately fit one if the chain doesnt rub the cases.
  • Captain Midnight
Posted August 09, 2005 - 10:41 PM
A 16 tooth will work fine.
  • sgifford
Posted August 21, 2005 - 07:07 AM
So was the conclusion on this that a 16 will fit? If so who makes a 16 that will fit the L? Has anyone actually put some miles on with that size?
  • wr450fyamaha
Posted August 21, 2005 - 10:22 AM
where exactly would i go about finding a 16 toot front? i have never seen one!!!!!!!!! it would be great on the street.....totaly suck in the dirt.
