Heatlight quit working
4 replies to this topic
  • 02WR426Cali
Posted August 01, 2005 - 09:46 AM
I have an 02 wr426 and I wanted to go for a nightride this past weekend but the headlight didn't work. I worked perfectly fine the weekend before. I started up my bike and the headlight wouldn't turn on. So I took it all apart and checked the bulb and there was nothing wrong with it. I put everything back together and it worked. So I let the bike idle while I got my helmet and gloves. So then I got on my bike, put it in first gear and the light went out. I took it apart again but no luck this time. There must be a short in the wiring somewhere. Has anyone else had any trouble like this?
  • 5valve
Posted August 01, 2005 - 11:44 AM
I had the same problem
it was a bad connector on the headlight wire wich is approx 8in from the bulb
pull apart (wires out of plastic connector) with the help of miniature screwdriver, clean & reconfigure the contacts
join and observe if successfull
  • kbryant3399
Posted August 01, 2005 - 03:03 PM
If you have a brake light switch, make sure its fully connected. Mine came slightly disconnected and all light went off.
  • Orangeman64
Posted August 01, 2005 - 07:22 PM
I had a YZ fender on mine and blew out 3 head light bulbs, hooked up the stock WR fender with tail light and no problems. The headlight must pull to much all by itself. I have noticed the connctor to the headlight gets loose, just tighten it up some.
  • flatnacker
Posted August 01, 2005 - 07:53 PM
WOW you have a heat light!!! cool!! that would be awesome for those cold winter mornings :D
