license plate mounting
16 replies to this topic
  • moach1
Posted July 31, 2005 - 04:06 PM
where and how is the best way to mount a license plate on a wr? been looking for the type that mounts under the back fender and hangs down, but cant find it
  • Strattos
Posted July 31, 2005 - 04:12 PM
Best i've seen, but I think you can only get them in Australia, is an aluminium one made by Pro Fast.
You could easily get one made up though...its simply a piece of aluminium around 20 - 25cm long and about 5cm - 10cm wide which has mounting holes lining up with the bolts/screws holding the tail light on.
Just bend it so its the right angle and screw your number plate on. Its quick and easy to put on and off.
Jeez i need to get a digital camera so i can post pics...be heaps easier.
  • Skip 04 WR250F
Posted July 31, 2005 - 04:23 PM
Ballards sell them here in aussie?
i am getting one delivered this week i can post a digital pic of one if you want
or goto this link, is under WRF # plate carrier
http://www.ballards....4792094362-1412
  • extex
Posted July 31, 2005 - 04:51 PM
Check this out
http://www.tnrdesign...motorcycles.htm
I just got one and it works great. I tried to mount it with steel strapping but it didn't stick out far enough and the tire ripped it off twice. This thing is solid, mounts with existing bolts and I've had no problems.
  • bg10459
Posted July 31, 2005 - 05:25 PM
I made one out of a piece of sheet aluminum in about 30 minutes. If I only knew how to post the pic. :D
  • xyzracer
Posted July 31, 2005 - 05:30 PM
www.fourstrokesonly.com has a small, light, aluminum bracket the works perfect.
  • PBDBLUE
Posted July 31, 2005 - 06:00 PM
Scotts :D
http://www.scottsper...e=5&Bike=Yamaha
  • dirtr1der
Posted July 31, 2005 - 07:25 PM
I made a cheesy one out of an "L" bracket and a plate frame. Had to drill my fender, but it works just fine. Added skulls to annoy my friend.
http://img.photobuck.../Newplate21.jpg
  • Blaster21996
Posted July 31, 2005 - 07:42 PM
Check this out
I have tries the SCOTTS model and another one by BAHA DESIGNS and this is the best of the lot.
  • moach1
Posted July 31, 2005 - 08:24 PM
cool, thanks for all the input. i like the scotts and the tnr designs. now i have to decide! thanks again
  • Blaster21996
Posted August 05, 2005 - 10:01 PM
Here you go, buy my plate holder.... http://cgi.ebay.com/...me=STRK:MESE:IT
:D
  • bg10459
Posted August 29, 2005 - 01:15 PM
I just got around to posting a few pics. Here's one of my plate holder. Materials were free and it took me about 1/2 hour. Of course, you learn from your mistakes. Next one will be even better.
http://i21.photobuck...59/DSC01034.jpg
  • Bamster
Posted August 29, 2005 - 02:51 PM
Bend a piece of aluminum and drill 4 holes in it.
Thats what I did. Made a couple of spares while I was at it.
  • Joe Reitman
Posted August 29, 2005 - 05:52 PM
I went a similar route- except I used sheet metal - steel- instead of aluminum. Probably about 20 gauge or so. Shaped like a "T". The bottom of the T faces the front of the bike and attaches to the bolts that hold in the tail light assembly. The top of the T is bent down about 25-30 degrees and hoLds the plate and "turn signals". Makes for a very clean install such that you do not even see the holder, just the plate. :D
  • skidxr
Posted August 29, 2005 - 06:07 PM
I have tried just about everything and it still gets beat to crap when it's under the fender.. I recently mounted it on top of the fender right in front of the tail light and it's still there.. I don't think it's just the tire that gets it but also the rocks kicking up..
  • bg10459
Posted August 29, 2005 - 08:13 PM
The rocks definitely destroy it. Good idea to make more. My plate gets it too, so I mounted that on a 1/4 thick piece of neoprene rubber. It saves a bit of abuse.
  • Matty05
Posted August 29, 2005 - 08:20 PM
$25 Australian! :D
