2005 Quick Reference Guide
5 replies to this topic
  • clark4131
Posted July 30, 2005 - 01:34 PM
I was bored at work today, so I went through the service manual and pulled out a bunch of stuff that I seem to be repeatedly looking up. I included a bunch of basic stuff like oil type, tire sizes, etc., along with page numbers to regularly performed procedures and some common torque specs. I didn't go into the transmission or anything in the engine beyond valve adjustments. I figured if you're that good, you already know where to look. This was primarily for those of us at the 3-4 wrench ability level that can tackle most of the routine, yet complex procedures. Be forwarned however, these apply to the '05 WR450 and therefore may not be the same for your model. With that said, here it is in all its glory. Feel free to augment, copy and/or distribute...SC
[COLOR=Navy]2005 Yamaha WR450FT Quick Reference & Index [/COLOR]
General Information
Motor Oil - 10W30 API Type SG
Oil Capacity - 1.16 US Qt. (w/ filter change)
Coolant Capacity - 1.65 US Qt.
Spark Plug - NGK CR8E (.028” - .031” gap)
Sprocket Ratio - 14:50
Tire Size - Front: 80/100 - 21 (15 PSI)
Rear: 110/100 - 18 (15 PSI)
Drive Chain Slack - 1.9” - 2.3”
Front Axle Nut – 22mm
Rear Axle Nut – 27mm
Steering Shaft Nut – 30mm
Main Jet – 165
Pilot Jet – 45
Pilot Air Jet – 80
Starter Jet – 65
Leak Jet – 50
Procedure Index
Coolant Replacement 3-12
Oil Replacement 3-21
Valve Clearance Procedure 3-26
Suspension Compression/Rebound Adjustment 3-43
Carburetor 5-2
Clutch 5-47
Water Pump Shaft/Impeller 5-56
Front/Rear Wheel 6-1
Front/Rear Brake 6-11
Front Fork 6-26
Steering Head 6-46
Swingarm 6-52
Rear Shock 6-60
Common Torque Specs
Front Axle Nut - 75 ft/lb (105Nm)
Front Axle Pinch Bolt - 17 ft/lb (23Nm)
Rear Axle Nut - 90 ft/lb (125Nm)
Upper Engine Bracket/Frame - 40 ft/lb (55Nm)
Upper Engine Bracket/Engine - 37 ft/lb (52Nm)
Lower Engine Bracket/Frame - 24 ft/lb (34Nm)
Lower Engine Bracket/Engine - 50 ft/lb (69Nm)
Spark Plug - 9.4 ft/lb (13Nm)
Cylinder Head Cover Bolt - 7.2 ft/lb (10Nm)
Camshaft Cap Bolt - 7.2 ft/lb (10Nm)
Timing Chain Tensioner Bolt - 7.2 ft/lb (10Nm)
Timing Chain Tensioner Cap Bolt - 5.1 ft/lb (7Nm)
Drive Sprocket Nut - 54 ft/lb (75Nm)
Rear Sprocket Bolt – 36 ft/lb (50Nm)
Rear Oil Drain Bolt - 14ft/lb (20Nm)
Side Oil Drain Bolt - 7.2 ft/lb (10Nm)
Frame Drain Bolt - 17 ft/lb (23Nm)
Oil Filter Drain Bolt - 7.2 ft/lb (10Nm)
Oil Filter Cover Bolt - 7.2 ft/lb (10Nm)
Water Pump Housing Bolt - 7.2 ft/lb (10Nm)
Upper Subframe Bolt - 23 ft/lb (32Nm)
Lower Subframe Bolt - 21 ft/lb (29Nm)
Upper Shock Mounting Bolt - 40 ft/lb (56Nm)
Lower Shock Mounting Bolt - 38 ft/lb (53Nm)
Swingarm Pivot Shaft - 61 ft/lb (85Nm)
Relay Arm/Connecting Rod Nut - 58 ft/lb (80Nm)
Relay Arm/Swingarm Nut - 58 ft/lb (80Nm)
  • extex
Posted July 30, 2005 - 04:34 PM
Thanks Steve. I printed it out because I am usually thumbing through with greasy fingers looking for that stuff.
  • RB2
Posted July 30, 2005 - 05:06 PM
I second that. :D
  • Blue Rocket
Posted July 30, 2005 - 05:28 PM
Good work Steve. Very handy guide.
I downloaded a PDF version of the 2003 manual from ftp://64.242.152.91/pub/manuals/ and then print the pages for the work i'm going to perform but this is still a handy reference. :D
  • Beejay
Posted December 01, 2006 - 04:28 PM
Aaaaah, many thanks, been meaning to do something like this for ages now.
Very handy.
  • skid567
Posted January 17, 2009 - 11:26 AM
Hi just found out that iv'e got the fifth gear problem on my 05 wr450!!. Would i be right in ordering the parts from the 07 model to sort this out as yamaha did something to the trans in 07's model and i would like to think that this sorted out the slipping problem that the early one suffered from. Or do i just have to stick with 05 parts????
Thanks Skid
