critical carb failure!
3 replies to this topic
  • poffer
Posted July 30, 2005 - 02:48 AM
A friend of me has a wr400f year 2000. Last time he used bike it started to rev with the throttle closed and very strange noise came from engine. When he got back home and checked the compression it was poor.... After removal of cylinder head he performed a leak test on the valves and they where leaking... At first no visual damage to valve, cylinder or piston. After inpection of carburator he saw that parts of "valve,neddle" were missing and what was left of it had cracks. (see, exploded wiew of carb, part nr 11) The parts had been sucked into engine and damaged valve and seat.
He has asked "yamaha people" about this issue but they had never heard of this before. Anyone here who has exp the same?
  • unkle_george
Posted July 30, 2005 - 06:25 AM
Is that the slider plate .... There are a few threads here about not getting the o-ring back on right and injecting broken pieces of the slider into the engine.
It's a semi-common problem.
- Ryan
  • ovrrdrive
Posted July 30, 2005 - 08:13 AM
I've seen several people saying that has happened to them too...
A search for "cracked slider" will return several results like this one...
http://www.thumperta...=cracked slider
  • poffer
Posted July 30, 2005 - 09:18 AM
yes it's the slader plate. Strange that yamaha norway didnt know about this since it look like this is a well known problem.
