Air Screw...Where it go???
7 replies to this topic
  • taksx
Posted July 29, 2005 - 01:35 PM
So i Just got this 05 WR450, And got this trip plan out for 6500' up in the local Mountains Tomorrow. I'm trying to re jet for that elevation...
But i cant find the darn thing (air screw) i know where the hot plunger is and that big black knob that i believe is the idle knob, And i know for a fact that it has to be on that side somewhere next to the gas line, But the air screw is no where to be found hahaha what a monkey i am. :applause:
A little help guy's i feel like a true noob. :eek:
  • bg10459
Posted July 29, 2005 - 01:43 PM
On a 4 stroke it's a fuel screw, and it's located in front of the float bowl on the bottom. You might need a mirror to see it.
  • berg
look on the botttom of the carb in front of the float bowl and you will see a plug that hides the screw. I just ran a screw up the center of the plug and yanked it out with pliars, then you can adjust it with a small screwdriver.
good luck Phil
  • rtrolli69
Posted July 29, 2005 - 06:41 PM
remove the plug that covers it and buy a zip ty fuel adjuster or another brand.The knob will stick out the bottom with#'s on it then you can fine tune and adjust with your fingers..like elevaton changes its great.
  • taksx
Posted July 31, 2005 - 07:55 AM
Thanks guy's :D Found it, Took care of it, Re jet it.
That's kinda of dumb place to put an air screw :D , But looks like the Zip Ty set up is a must.
  • Rich_in_Orlando
Posted July 31, 2005 - 05:21 PM
Just to reiterate, it's a fuel screw, not an air screw. That's why it seems like a dumb place to put it to you. It behaves the opposite way an air screw does. Turn it in, it leans the mixture. Turn it out, it richens the mixture.
  • taksx
Posted August 01, 2005 - 02:26 PM
Got it. I will never call it a Air screw again :D
Where did you guy's get that after market mix screw?
I looked in the TT store but only saw the 2 stroke screws.
Are you guy's buying them strait from Zip Ty?
Thanks, Eddie.
  • Orangeman64
Posted August 01, 2005 - 07:28 PM
That's where I got mine, right from Zip tye
