05 Wr450
8 replies to this topic
  • Tbone81
Posted July 27, 2005 - 10:22 AM
Just got it and ride between 3000-8000'. I have about 60 miles on it now and have installed an FMF Q pipe, skid plate and radiator guards. It really runs good at the upper rpm level but stumbles mid range (saw the jetting thread and will experiment). I have not cut the grey wire or performed any jetting thus far. Would like suggestions for improvements. This is a really nice bike; I was riding an 87 XR600 and the weight/suspension and acceleration are a lot nicer on the WR.
  • Indy_WR450
Posted July 27, 2005 - 12:35 PM
Try and disconnect your TPS on the left side of the carb and see if your midrange stutter goes away. It only takes a few seconds. If not then rejetting will be necessary to richen the midrange. :applause:
  • SXP
Posted July 27, 2005 - 04:39 PM
Hey Indy - Did you get 490cc by boring only, or did you also stroke? Who did you use. Thanks :applause:
  • Indy_WR450
Posted July 27, 2005 - 06:21 PM
I was going to stroke it with a Falicon heavy stroker crank to a 502 kit but they wanted 10 weeks to deliver it. I had to rebuild her with a standard new crank. :applause:
  • Tbone81
Posted August 01, 2005 - 07:09 PM
OK disconnected and ran fine but terrible backfire so I reconnected. I was at 8,000 ft plus. It runs OK but the way it ran with the TPS disconnected was great. Just need that backfire to go away.
  • johunter666
Posted August 01, 2005 - 09:02 PM
Spend $65 for the JD jet kit and another $20 for the zip-tie fuel screw. If you like your bike now, you will LOVE it after these mods. Go to the jetting forum to get hints on the setup. :D :D
Todd
05 wr450
fmf Q, jd jet kit, zip-tie fuel screw
  • extex
Posted August 02, 2005 - 05:42 AM
Also, remove the AIS. TT sells a plug kit.
  • Dan_Lorenze
Posted August 02, 2005 - 06:48 AM
I'm not sure what main jet you have in there now, but that or the needle position has got to be the culprit (I'm assuming the grey wire is pulled).
  • Dan_Lorenze
Posted August 02, 2005 - 06:49 AM
[quote name='Dan_Lorenze']I'm not sure what main jet you have in there now, but that or the needle position has got to be the culprit, you've got to cut the grey wire too.
