First Valve check how many of your bikes needed adjusted??
14 replies to this topic
  • snow
Posted July 22, 2005 - 03:51 PM
Have about 8-10 good full rides on my bike and I was wondering how many of you took your bike in and found your valves out of spec?? I asked my dealer about this and he told me that he would not worry about my bike sice I don't race and he has seen lots of 426's that are fine what do you think???
  • yzf450jack
Posted July 22, 2005 - 04:09 PM
Don't worry about it's not a Honda :eek: Mine is still in spec.after 3 year's :applause:
  • 642MX
Posted July 22, 2005 - 05:58 PM
Mine have never needed adjustment either.
Posted July 22, 2005 - 06:00 PM
I did the first ever valve adjust on my 250F in May or June of '04. The 450 still doesn't need it.
  • racer8
Posted July 22, 2005 - 09:32 PM
Over a year here, cked them four times,
and all with in specs.
  • djo269
Posted July 22, 2005 - 10:58 PM
my 2002 yamaha yz250f has been rock solid. the first valve check (fall of 2004 sometime?) all were within spec.
  • johnmeasures
Posted July 23, 2005 - 02:31 AM
Checked my YZFs every 15hrs use & they never needed adjusting.
Sold after 1year, still ok
  • 99raptor
Posted July 23, 2005 - 05:42 AM
Mine has been fine at 1yr.
  • rmracer27
Posted July 23, 2005 - 11:33 AM
Mine has about 30 hours on it and they are still in range.
  • John407
Posted July 23, 2005 - 11:45 AM
I've checked mine a couple of times, they were still in spec on my YZ450 , but they were also in spec on my KXF250. Maybe as long as they ain't Honda'sthe valves will last?
  • yamaha9985
Posted July 23, 2005 - 11:11 PM
How will the engine run (if at all) if they were out of spec?
  • Anssi
Posted July 24, 2005 - 10:11 AM
The engine will run just fine unless they are off big time (too little (which is the way they will go when they wear out) and you could end up with burnt valves, too much and you get noise from the valve train).
I needed to adjust them a bit after break-in (10 hours or so), but after that, they were still in spec after 135 hours, when I replaced the valves and springs.
  • rich-tenerife
Posted July 24, 2005 - 10:25 AM
Hi Snow , Everytime i check, they are within spec.I have just covered 10,000km, the first owner did around 6,000km.
Now my 2002 WR 426 F sonud's and pull's stronger & stronger !
Never been adjusted , but oil changed every 1,500 km.
That seems to help.
Good Luck
  • yamadoggy
Posted July 24, 2005 - 03:00 PM
Mine were out of spec. when I first got it (only very slightly). 05 yz450 if it matters
  • 35yz450F
Posted July 24, 2005 - 07:47 PM
My middle intake valve was out of spec after break in. Nothing has budged since.
yz400f throttle bog by yz400fmaniac
  • Hot  28 replies
Need help by Goforaride
  • Hot  68 replies
  • Hot  28 replies
  • 0 replies
  • Hot  79 replies
