choke and hotstart questions
4 replies to this topic
  • radish150
Posted July 21, 2005 - 10:03 PM
On a good running properly jetted 99 400, when hot... what effect should it have on the bike if you suddenly pull the choke out for no good reason when it´s hot and idling? Should it die, slow down, or run faster? Also, same question for the hot start... what should the bike do from a hot idle when you suddenly pull it? I think my bike is finally getting really close on the Jetting, but am curious about this.
Mark Sheldon
  • Math
Posted July 22, 2005 - 04:46 AM
The bike should die on the choke.
My WR just idles very very roughly with the hot start on when not necessary and will dye if I don't shut it soon enough.... well now the problem is not occuring anymore because I've upgraded with a DrD hot start... it works sooo nice! But then my jetting is not perfect yet.
  • MattyH
Posted July 22, 2005 - 06:17 AM
hotstart is the opposite of a choke in that it leans out the air/fuel. by rights the bike shouldnt die with the choke on until it fouls the plug cos it'll just have been running richer
  • Rich_in_Orlando
Posted July 22, 2005 - 07:31 AM
You will kill it if you pull out the choke when it's already warmed up. Trust me, I know from experience.
  • Rich_in_Orlando
Posted July 22, 2005 - 07:32 AM
If you pull out the hot start, it will run faster at first then it will die.
