YZ storage
10 replies to this topic
  • tnl
Posted July 21, 2005 - 08:47 AM
I'll be out of commision for probably a month or so. Are there any storage requirements that I need to do to preserve my bike like drain the carb.? Say let the bike run with the gas valve off till it dies.
Thanks
  • Stonie426
Posted July 21, 2005 - 08:52 AM
tnl,
Fully drain tank and carb. Wind the kick starter upto compression (this closes all the valves to stop moisture entering the cylinder and takes the pressure off the valve springs). Put bike on a stand.
Stonie426.
  • viggen
Posted July 21, 2005 - 09:15 AM
is it needed when t's only going to be sitting for a few weeks? I don't beleive gas brakes down that quick, but maybe I am wrong??
I would think just throw it on a stand & that's it :applause:
  • fastenuf4u
Posted July 21, 2005 - 09:33 AM
tnl,
I doubt 1 month is long enough to go to drastic measures for "long term" storage. My bike has been sitting on my trailer in the garage for at least a month at a time when I couldn't ride and she fires up with 2-3 kicks. I do drain the fuel out after it has sat that long and replace it.
Posted July 21, 2005 - 09:46 AM
A month is a pretty short time, alright, but it's hot in Mississippi. I won't take that long to drain the carb (there's a little screw there on the bowl for the purpose) and the tank. Modern pump gas can't always be trusted to hold up very well in storage, really. Most times, it will be OK, but I've seen it turn into an unidentifiable (and even non-flammable) liquid in a month before.
Closing up the valves is a habit you should always have.
  • MisterMan
Posted July 21, 2005 - 08:10 PM
put bike on stand, flatten tires...pull out choke.... put at beg. of compression....drain entire tank, chain it up so it wont get stolen.
Posted July 21, 2005 - 08:28 PM
Why pull out the choke?
  • cowboyona426
Posted July 21, 2005 - 08:41 PM
Here's a little trick I use to close the valves and set the piston to TDC- put the bike in first gear and pull it backwards until the front tire starts to lift up. Put it back in neutral and throw it on the stand :applause:
  • MisterMan
Posted July 21, 2005 - 09:36 PM
....wait..../w/ these bike do they have a valve that closes half of the throat in the carb to create a ritcher mixture????...if so, thats why, it closes theintake into the carb.
Posted July 22, 2005 - 07:29 AM
Nope, the "choke" is an enrichment valve, like a two-stroke carb, not a true choke plate.
  • snow
Posted July 22, 2005 - 11:57 AM
Don' you want to keep the tank full during storage so the moisture or water doesn't collect. I always fog my snowmobile engines. Also if you ever get to talk to a airplane guy they will tell you that when they tear down old WWI aircrafts the carbs look like new because of the AV Gas so I put a 50/50 mix of that in the tank too or I run sea foam.
  • 10 replies
  • Hot  47 replies
  • Hot  36 replies
  • 0 replies
