Idle/Throttle Problem?
3 replies to this topic
  • Lok47
Posted July 20, 2005 - 10:14 PM
Well, I just installed the throttle slide plate and throttle cable. Everything is in and I'm able to start and ride the 400 now. But, my problem is that when I crack the throttle and get off it, the throttle seems to stick. For instance, it will idle fine until after I rev it. After revving it, it'll still sound as if the throttle is on a little for about 10-15 seconds and then it will go back to idle speed. It sounds as if the throttle is still on a little, so I'm not sure if it's a carb thing I need to fix or just bad throttle cable adjustments. This is my first time doing either, so I really don't know where to begin. Any one have any suggestion or tips? Any tips for adjusting the throttle cables?
  • Matty05
Posted July 20, 2005 - 10:29 PM
your idle adjuster (black knob) sounds like it is wound too far in.
  • flatnacker
Posted July 20, 2005 - 10:32 PM
Yep thats what I reckon-same happened to mine when I first got it.
  • Rich_in_Orlando
Posted July 21, 2005 - 06:02 AM
Did you install the o-ring properly on the back of the slide plate? The smooth part of the o-ring needs to face the plate. You may have some air leaking around the plate.
