Suspension Settings 05 450
9 replies to this topic
  • sausage boy
Posted July 19, 2005 - 10:28 AM
my 05 450 handles like a pig, compared with my mates 04, I'm wanting to try some different settings, I'm 6'2" 190 pounds with a fairly aggressive riding style. thanks :applause:
  • rushfan
Posted July 19, 2005 - 12:18 PM
Have you done any adjusting to the suspension settings yet? If not, read the manual and set them to standard and start from there.
Also, you might want to replace the front tire. Consider the Maxxis IT.
  • sausage boy
Posted July 19, 2005 - 02:24 PM
I have done a few minor adjustments from the stock and dropped the forks down to the first notch, i have also ordered a Maxxis IT which should be delivered tomorrow, I'll put it on before the weekend and give it a try. the suspension is at its worse when I'm going up steep single track climbs, it bounces and skips on the back, the front was bottoming out, I've sorted that, but in sorting that the forks feel harsh when you hit unsuspecting rocks.
  • Anthony CRF450
Posted July 19, 2005 - 02:53 PM
hi my name is anthony from melbourne Australia. i have the same problem. i ordered a new front tyre too. and softened the suspension two clicks (front rebound &compression). the back tends to buck me off at high speed so i will back the rebound off. my 04 crf was the same when new. the best way to fix it is know what setting are where and go for a ride. make adjustments on the side of the trail and seee how it works. i hope this helps simple and inexpensive! by the way what free mods did you do on your 05?
regards anthony
ref pic from anglesea (melbourne)
http://i2.photobucke...00-0009_IMG.jpg
:applause:
  • rushfan
Posted July 19, 2005 - 03:24 PM
Hey Anthony. When you say you softened the front two clicks, do you mean from the standard setting? :applause:
  • sausage boy
Posted July 19, 2005 - 03:38 PM
regards anthony
:applause:
disconnect the grey wire, cut the throttle screw down,removed the small baffle in the exhaust and removed the air box snorkel. :eek:
  • Anthony CRF450
Posted July 19, 2005 - 03:50 PM
thats right. from stock two clicks at a time. then ride for a bit and leave or turn more (depending on the conditions)
  • jasilva
Posted July 19, 2005 - 09:31 PM
If the rear is kicking and bucking then you need More not less rebound damping. If your front is too soft go to the next stiffer fork spring. If you up the compression damping to compensate for bottoming you'll just make the fork harsh on small hits. If the fork feels good over most bumps and jumps and just bottoms when you hammer it hard, like when you hit the face of a water break on an uphill then you may just need to raise the oil height a bit to prevent bottoming without making the first part of the travel too stiff. Go 5mm at a time on the oil height. If you need to raise the oil more than 10mm then you need a stiffer set of springs.
Joe
  • jasilva
Posted July 19, 2005 - 09:34 PM
Hey sausage boy, if your stock 739 isn't worn out send it my way. :applause: That's a decent front tire for most terrain.
Joe
  • sausage boy
Posted July 20, 2005 - 10:35 AM
Joe
hey joe,
i did add 5cc of oil to the forks, i also up'ed the compression 2 clicks and -1 click of the rebound. half way through the ride i took 1 click off the compression, which made it loads better. i'll try more rebound on the rear, thanks.
if you want the tire its yours, its done 500 miles :applause:
