some silly questions!!
1 reply to this topic
  • illikonoz
Posted July 19, 2005 - 04:19 AM
hi guys, here are some silly mod questions...
1. will a rear brake pump from newer 04' yz fit the old wr400f mounts? :p
2. will a 40mm crf carb bring on any benefits to a wr400 with hotcams and bigbore kit (440cc) or should i just stick on to the 39mm ones...? :p
3. and should i cut holes on the air box to make it breathe better? :applause:
thanks for helping me solve all this mystery !! :) :eek:
  • Brettv
Posted July 19, 2005 - 04:42 AM
not sure bout the crf carb, i doubt it would make much diff, could even make it worse, i would stick with the 39mm.
the rear master cylinder should fit, and will eliminate the plastic external resovoir
yes cuttin holes in the airbox will make it breathe better, but u need to be careful about dirt/water entering the air box, put some round plastic inserts and fish filter foam and it should be ok.
remember to rejet cause itl lean out.
