Suspension or Rekluse?
29 replies to this topic
  • spdfrek
Posted July 18, 2005 - 02:04 PM
I'm getting into racing hare scrambles on my 05 yz450f,Which do you think would make a better investment?The rekluse or suspension made for my weight and the riding i'll be doing?
  • 642MX
Posted July 18, 2005 - 03:56 PM
I've got both done on my 426, and the Rekluse was by far the better of the two.
  • ncmountainman
Posted July 18, 2005 - 05:14 PM
if its tight stuff your gonna need the rekluse. i run 13/52 on my 05 and 1st is still a little tall,but i can't go any lower as top speed has been reduced to the mid 60's. as far as the suspension the forks definately need help from stock for offroad use,factory connection seems to have a handle on the new aoss forks. the 05 shock is awesome as long as its sprung for your weight :applause: some radiator protection and brushgaurds are a must also :eek:
  • RADRick
Posted July 18, 2005 - 06:25 PM
The Rekluse will only benefit you in the types of riding it was designed for, primarily tight trails. Suspension mods will make the bike more rideable everywhere. If you weigh more than 175 lbs. (without gear), you have no idea how good your bike's suspension could be. Most bikes come from the factory set up for a 150 lb. rider. The difference between my stock WR450 and after I had Race Tech completely rework it is night and day. For a heavier rider, suspension mods will make them faster than a few engine mods will. Make the bike handle first, then worry about making it faster. :applause:
  • jerryls
Posted July 18, 2005 - 07:20 PM
I'm with Rick. If your racing, get the suspension done first. You'll be amazed. Night and day difference. Buy the Rekluse after that.
Jerry
  • snow
Posted July 18, 2005 - 08:05 PM
Ok I ride in the dunes and in the woods and I am 155-160. So what can I do and what would it cost. Can I have a set up that would be good for bolth or easy to adjust?? Also what about the rear. I know nothing about the forks. :applause:
  • yz_for_me
Posted July 18, 2005 - 08:33 PM
That's a tough one but unless you are way outside the "normal" weight range for these bikes, I think the Rekluse would be a better investment. Here's my reasoning.
The Rekluse will pretty much eliminate all stalling. Unless you have a heavier flywheel, the 450 is prone to stalling. In a Hare Scrambles you will be in a lot of stall prone situations. Each time you stall will cost you a lot of time.
The other thing I've noticed is the Rekluse allows me to ride hard for much longer. In my case anyway, pulling in the clutch was a major factor in arm pump and fatigue. In a long race like a hare scramble, endurance will be a major factor.
Finally, the suspension on the '05 is pretty good right out of the box. There is a lot of tuning you can do with the stock boingers to get the set up for hare scrambles. So like I said, unless you are way outside the weight range for the bike, the stock setup should be pretty good or at least workable.
  • Satch0922
Posted July 18, 2005 - 08:45 PM
Answer.....BOTH.
The rear of the YZF is fine ...assuming it has the right spring.
The forks need help. Get them revalved and you will be amazed. They are not terrible from the factory...but they are SOOO much better if you have someone good revalve them.
  • spdfrek
Posted July 19, 2005 - 02:30 PM
Satch,your ol 426 was at the hare scrambles on sunday too :eek: he placed 5th.Got buried in a mud hole for a few minutes...his first lap was 8 minutes behind mine.I took first,esley took second...We were all riding open c.Anywho,from what ive found i need to do different springs for the bikes intended use.So suspension will cost me around the $600 mark.But i had custom stuff on my 01 yz250,and i know it can make a heck of a difference :applause:
  • Satch0922
Posted July 19, 2005 - 04:35 PM
Sweet ..."Ole #9" got 5th! Still out there giving it hell I hope. Thanks for the update!
  • snow
Posted July 19, 2005 - 06:03 PM
Anyone know of any races in Montana or semi close to Bozeman that I could get started in???
  • spdfrek
Posted July 19, 2005 - 07:16 PM
bozmen is a bit of a drive from here,but theres a harescrambles at terry peak sd in august,september theres a harescrambles in marion nd,and october theres another hare scrambles at the price ranch north of mandan again.
Satch,hes out there making people work to win :applause: tonight i talked to him online,he wants to know when the next race is,he has a need to do better....lol...hes hooked...you should come up and do some harescrambles with us,and become friends with the tree's :eek:
  • snow
Posted July 19, 2005 - 07:33 PM
I am planning on the one in SD I just can't figure out why we don't have any races in Montana at least Pipestone I mean theres 600 + miles or trails. Also how many people do you think are at these on average?? I think I'm going to suck but it should be fun.
  • spdfrek
Posted July 19, 2005 - 08:31 PM
The first one i was at,there was a lil over 100 riders there,this one id say about 60 or so.Terry Peak I think may be a bit larger race,considering location and such.If you suck,or if your good,its all about having fun.And this is a blast.
  • djbiker
Posted July 20, 2005 - 11:26 AM
personly i think that the auto clucth is stupid, i takes all the fun out of big bikes, i rode one that had it, it was like riding a pw50 or something, it had not hit, took to long for it the fully grab
go for the Suspension
  • spdfrek
Posted July 20, 2005 - 12:31 PM
no hit isnt a bad thing when your handlebars only clear the trees by half an inch on each side
  • snow
Posted July 20, 2005 - 04:26 PM
I don't think the auto clutch takes hardly any hit away or am I wrong??? maybe he had his set up wrong???
  • ncmountainman
Posted July 20, 2005 - 06:27 PM
the rekluse makes my yz hook up better,its all in the wrist. after full engagement the rekluse actually has more clamping pressure than a stock clutch with springs. once ya figure it it out(it doesn't take long) its a huge advantage for tight offroad riding. and for those who say its cheating? it just might be! :applause:
  • rmracer27
Posted July 21, 2005 - 03:18 AM
If I had to decide first I would go with the Rekluse. The suspension on the 05 is good already. I have done both but the rekluse is what I like the best. It does make the bike hook up better and does not take away the hit. It is perfect for racing hare scrambles. I would hold off on the suspension and go with the rekluse.
  • yz_for_me
Posted July 21, 2005 - 08:52 PM
I can't say how the one you rode was set up, but I know mine hasn't lost any hit. Maybe the one you had was setup to engage at too high an RPM for your taste? Just a guess. Mine hooks up right off idle and the only time it takes to long to fully engage is when I'm in too tall a gear. As long as I keep it in the right gear the thing flat out rips.
