Overflow leaking
13 replies to this topic
  • martis_d
Posted July 18, 2005 - 04:25 AM
coolant come out of the rad overflow all the time even when transporting my bike :applause:
  • Daz_426_02
Posted July 18, 2005 - 06:53 AM
Need more info man... how you transporting it? How much coolant are you loosing?? Did you over fill it??
  • martis_d
Posted July 18, 2005 - 08:03 PM
i transport is in my ute. loosing enough to start to worry about it. no it has not been over filled
  • MisterMan
Posted July 18, 2005 - 08:38 PM
is it hot? is it cold, if cold, get a new cap.
  • mkporn
Posted July 18, 2005 - 09:26 PM
Get a new cap.... :applause:
  • martis_d
Posted July 19, 2005 - 03:23 AM
cheers man i will give it a go
  • martis_d
Posted July 19, 2005 - 03:43 PM
is that weather wise or running temp? :applause:
  • crfmatt
Posted July 19, 2005 - 04:40 PM
That would be running temp.
Posted July 19, 2005 - 06:20 PM
Are you sure that it's from the overflow? That tube ends in the same general area where a few possible leak points are located. Double check. You might have a drop or two fall from the tube after the bike is loaded up, but there is no reason for it to lose coolant out of the overflow more than 5 minutes after it's shut off. Check the impeller shaft leak port on the bottom of the engine cover just behind the water pump.
Hint: Clean coolant trails can be hard to trace on an aluminum surface. Dust the area with baby powder and the trails will stand right out.
  • martis_d
Posted July 19, 2005 - 10:11 PM
it is out of the overflow i have seen it come out.
  • martis_d
Posted July 19, 2005 - 10:14 PM
does anyone have pics of the overflow tank mod done on an 03 yz450f ? i done a search on it but none of the pics worked!!
  • CRFThumper
Posted July 20, 2005 - 04:51 AM
I would check the cap as well!If its not to full and its leaking while its being shook around it must be a problem with the cap!!!
  • CRFThumper
Posted July 20, 2005 - 04:52 AM
HA!!! im a sliver member now!!!!!!!!!!took 5 years but never mind im silver HA!!!!!!!! :applause:
  • mkporn
Posted July 20, 2005 - 07:21 AM
HA!!! im a sliver member now!!!!!!!!!!took 5 years but never mind im silver HA!!!!!!!! :p
Congrat's! :applause: :eek: :) :p :p :p
  • Hot  33 replies
  • Hot  79 replies
  • Hot  36 replies
  • 9 replies
  • 0 reviews
