Clutch problems??
14 replies to this topic
  • martis_d
Posted July 18, 2005 - 04:08 AM
I have a 03 yz450f the clutch makes wine noise and it doesn't dissengage properly but only does it when it is hot. :eek: :applause:
  • martis_d
Posted July 19, 2005 - 03:25 AM
help anyone please
  • walent215
Posted July 19, 2005 - 03:54 AM
i have an 03 also but with no problems .ive heard these bikes have had probs with the clutch and you can probably solve the issue with a hinson basket and new clutch. have you tried adjusting it?what type oil are you using?
  • martis_d
Posted July 19, 2005 - 03:40 PM
i have tried adjusting the clutch and changing oils from shell advanced to bellray thumper. i will be pulling the clutch apart today and measuring everything in there to see if it is spec. how is the hinson basket different and new clutch is that a aftermarket clutch plates or gen.
  • Pincushion
Posted July 19, 2005 - 03:42 PM
The Hinson basket has extral oil passages in the fingers to allow better oil flow onto the clutch plates. It may help in your situation.
How hot is was it when you were riding?
  • martis_d
Posted July 19, 2005 - 03:47 PM
it was getting real hot the header pipe had a blue glow to it. it was a tight trail so most of it was first gear
  • Ga426owner
Posted July 19, 2005 - 04:01 PM
help anyone please
do a search on this - there is tons of info on how to fix it....
  • mkporn
Posted July 19, 2005 - 04:05 PM
Stupid question....What kind of clutch lever set up are you using? Stock or other?
  • martis_d
Posted July 19, 2005 - 04:07 PM
I'm using a stock one. the problem is not with adjustment nor with the leaver action but internally
  • martis_d
Posted July 19, 2005 - 10:17 PM
I done a search but none of the pics worked and after reading all of them i was back to square one :applause:
  • martis_d
Posted July 19, 2005 - 10:19 PM
all the springs are within limits, the friction plales are ok but the steels are blue and have high and low spots on them but they seem not to be warped
  • Ga426owner
Posted July 20, 2005 - 04:35 AM
look for 03 yzf 450 clutch fix -
there is tons of info on the actual yamaha fix - the yamaha service bulletin with all the necessary parts to fix the 03 clutch
  • martis_d
Posted July 29, 2005 - 01:44 PM
there was also metal grab onthe inner basket and i drilled the oil gals out 1 mm bigger and so will see what happens this weekend
  • martis_d
Posted July 29, 2005 - 01:46 PM
the threads are old and none of the links work
  • martis_d
Posted July 29, 2005 - 01:47 PM
where else can i find the bulletin?
