Cheat valve clearance- loose or tight?
2 replies to this topic
  • donutman126
Posted July 16, 2005 - 11:41 PM
When selecting shims for valve adjustment do you “cheat” loose or tight? I am thinking the valve/seat wear along with stem stretch will tighten the clearance faster then cam/bucket wear will loosen it. I have the luxury of some factory “tweener” shims to choose from and I am thinking going to the upper end of the tolerance to extend periods between adjustments.
When you guys find your valves out of spec are they tight or loose? Thanks
01 WR426
  • Rich_in_Orlando
Posted July 17, 2005 - 02:38 AM
"cheat" loose - they tighten up over time
  • OLDFATGUYRACING
Posted July 17, 2005 - 05:05 AM
I always go to the loose side when I set valves :applause:
