To Mod or not to Mod...?
6 replies to this topic
  • nevadaoutlaw
Posted July 15, 2005 - 10:06 AM
Any suggestions on what mod. I should do next? Just looking for a little more horses, because I use the bike for Supermoto. In the dirt it was fine stock.
05 WR450F current mods:
YZ Throttle screw
Gray wire mod.
AIS removal
Zip-ty fuel screw
Yosh full exhaust /w header
Airbox opened up
Twin Air air filter
Jetting: 165 Main (#4 on clip), 48 Pilot (it maybe a little lean...I think)
  • jchantzWR400F
Posted July 15, 2005 - 10:59 AM
You could always try the yz450 exhaust cam. May make better power in the higher rpm's.
  • DIGITAL_SOLDIER
Posted July 15, 2005 - 01:04 PM
I'd say you're pretty much golden with what you've done. Not sure what else you can do. What is your gearing for S.moto?
  • nevadaoutlaw
Posted July 16, 2005 - 02:18 PM
Right now I am running the 14 in front and a 47 in the rear. I don't need a to go smaller in the rear that is for sure. Do you think a 48 or higher may make a difference?
Ya, I guess not much more I can do unless I starting putting cams in and that may not make much of a difference and I am not sure if I need to go there right now. I do need to open the airbox a bit more. I have the side cut outs cut out and the snorkle out, but I ran it without the side cover and it was very noticeable the increase in most all ranges.
  • rushfan
Posted July 16, 2005 - 02:45 PM
I'd say you're set. Leave the cams alone and ride! :applause:
How do you like that Yoshi exhaust?
  • nevadaoutlaw
Posted July 17, 2005 - 08:45 PM
Like the Yosh exhaust thus far. Much lighter, much more power, easy to change to the strick 96 dec. w/ spark arrestor.
  • rtrolli69
Posted July 25, 2005 - 07:39 PM
You might try the Pwr now plus sytem.Ive got it & love it..With this mod and JD jetting it was like adding the pwr again that you gained with your pipe!!more bottom&the midrange hits hard and pulls longer..a little $$$ but we all know thats what makes pwr..Russ
