2 questions '00 WR400
2 replies to this topic
  • Conan_'dale
Posted July 11, 2005 - 08:10 AM
Went riding this weekend (1st time on bike) and bike ran good.
1. During the ride when I would come to a stop and hold the clutch in the bike would maintain a high RPM and then 10-20 later it would drop down to the normal idle. Any ideas what is causing this?
2. My rear brake line burst/split and I found out while on a very steep hill that I had no rear brake. Does anyone know where I can get a steel braded line? Is this something I can get at a dealer?
  • Longtimeyamahaguy
Posted July 11, 2005 - 08:31 AM
My 450 does the same thing with the high idle, I haven`t gotten into the problem yet but I figure it is running lean. Mine will hold the idle so high that it seems like the throttle is stuck............. my results of this high idle/stuck throttle was a flip over going up hill. Broken rear fender and a bruised forearm!!!
  • storm 800
Posted July 11, 2005 - 01:59 PM
Try turning out your piolet air screw! Mine is out 2.5 turns with the FMF Q pipe. I had the high idle untill I did that.
