Kill it
6 replies to this topic
  • XriderR00
Posted July 10, 2005 - 08:25 AM
Not sure whats going on, but in the spring i painted my frame black and i might've hit some of the wiring for the kill switch i dont know.. but the kill switch no longer works. Not a big problem but its kind of nice to have.. Anyone know what i should do? :)
  • flintlock28
Posted July 10, 2005 - 08:53 AM
Get an Ohmmeter (Mult-meter), and check to make sure that the switch is working. My guess is that maybe you got paint overspray underneath the switch, and when you push it down, the excess paint is preventing electrical contact. just a guess, the meter will tell you if the switch is bad.
  • Hick
Posted July 10, 2005 - 11:44 AM
Also, you may have killed the ground contact at the coil mount. Rub some of the paint off here and try that.
  • XriderR00
Posted July 10, 2005 - 01:50 PM
I didn't paint up by the bars but i dont think its that..
  • DoctorRzed
Posted July 10, 2005 - 04:38 PM
Why would you paint the frame w/out everything taken off of it??? :)
  • XriderR00
Posted July 10, 2005 - 09:10 PM
Why would you paint the frame w/out everything taken off of it??? :applause:
Because it was much easier and less time consuming.. i took off the rads and seat, tank, and all that stuff then just taped everything off.
  • Chills
Posted July 10, 2005 - 09:14 PM
Just a note, but check the Bullet connector that connects the kill switch in to the wiring. I believe they are bullet connectors, i.e. corrosion, unpluged, ect, also check for any fraying of the wires or a possible break in the wire, but that can be veified with you multimeter...
  • 10 replies
  • Hot  47 replies
  • 5 replies
  • Hot  36 replies
