exhaust cam - a bit hard rotating
2 replies to this topic
  • 5valve
Posted July 09, 2005 - 11:03 PM
Im constantly changing between yz and wr timing on my 400, to suit the terrain, but since my last conversion was quite long ago, I lost the red line with the left side cam chain slider rubbing with some force into the chain, not allowing the cam to rotate 100% freely (by hand power), as the intake does
I test it with both cams placed, torqued and chain tensioner not yet applied
  • Chris_from_Oz
Posted July 10, 2005 - 12:56 AM
Are your cam cap bolts over tightened? :)
  • 5valve
Posted July 11, 2005 - 12:50 PM
no, they are torqued with the torque wrench
the chain is running pressed between slider and exhaust chain sprocket
it can rotate by hand but with a bit force
