throttle slide plate?
4 replies to this topic
  • Lok47
Posted July 09, 2005 - 07:42 PM
I posted about a month ago about my throttle slide plate being broken. So, I got the parts today finally from ronayers.com and I realized that there are actually two plates in the carb rather than just 1. But, when I go online and look at the fiche it just shows on slide plate. Is it safe to assume they are the same on both sides? This is a 2000 WR400F.
edit: Are there any aftermarket plates available? I'm assuming both of the plates should be sealed off because they look cracked on both sides.
  • Rich_in_Orlando
Posted July 09, 2005 - 08:41 PM
Geez, this is the first report I've seen of the carb slider cracking on 2000 and newer models. Mine has cracked 3 times in the last 2 years and I was thinking a newer model carb might cure this. Now, I'm not so sure.
  • dkwok
Posted July 10, 2005 - 12:16 PM
then get a post '01 or newer carb to be sure its way past '00,
all of our guys here have change to a post '00 carb wifout anymore problem,
my son got a '03 carb & we r very happy,
  • Lok47
Posted July 10, 2005 - 06:14 PM
Anyone know if the slide plate is the same front and back or is there a separate part? I'm in need of one ASAP!
  • Lok47
Posted July 10, 2005 - 06:29 PM
nevermind i'm an idiot. The vaccum valve deal is actually supposed to have a little opening. Sorry for the stupidity! :)
