klx110 oil change
5 replies to this topic
  • LostSouth
Posted July 08, 2005 - 10:16 PM
I picked up a used 2004 klx110 for my son a few weeks ago. It's time to change the oil, but I don't have the manual. Does anyone know how much oil it requires with and without the filter. I guess the filter is under the skidplate. Is there a gasket you need to replace when you take off the filter cover?
Any other suggestions?
  • mx221
Posted July 10, 2005 - 11:24 AM
the oil filter is not under the skid plate. it is mounted on the motor. it is round and has 2 bolts. there is a little window below either your brake or shift lever, when you add oil, stop pouring when the window is half full. no gasgets are required to change the filter. be careful when tightning the drain plug bolt, they strip/crack eaisly!
good luck
  • LostSouth
Posted July 10, 2005 - 11:41 AM
Thank you, I didn't think anyone was ever going to respond. I'd never used a window before and didn't notice the two lines until you mentioned.
  • 128racecar
Posted July 10, 2005 - 05:43 PM
My manual says 1.0 qt (0.9 liter) without filter change, 1.1 qt (1.0 liter) with filter change. :)
Anyone ever use Mobil 1 for oil in their KLX/DRZ110? :)
Marc in Indy
  • mx221
Posted July 10, 2005 - 07:36 PM
no, i use motul
  • Sangair
Posted July 11, 2005 - 07:20 AM
Anyone ever use Mobil 1 for oil in their KLX/DRZ110? :applause:
Marc in Indy
Marc,
If your going to use the Mobil 1 that is NOT made for motorcycle applications, make sure you use only the red or yellow cap bottles.
These do not have the friction modifiers and are cheaper then the Mobil 1 oil designed for motorcycles.
Sangair
Kawasaki KLX110L 2014 by Chris.GVS
  • 0 reviews
Suzuki DR-Z70 2014 by Chris.GVS
Suzuki DR-Z70 2014
  • 0 reviews
2012 klx110 mod by jMclear1
Dirt Bike   Make / Model Specific   Kawasaki   KLX 110
Setting timing on my Klx110 by yzkid_85
Dirt Bike   Special Interest Forums   Pit Bikes
Want to buy a 110 for my kid PLEASE HELP by fourtech
  • 8 replies
