suspension ?'s
6 replies to this topic
  • alfa
Posted July 08, 2005 - 01:19 PM
I have an '05 WR 450 and I was wondering what you guys are doing to stiffen up your suspension. I am bottoming pretty good over doubles, but otherwise it is great over everything else. Bigger whoops are sometimes a problem.
  • Texas4play
Posted July 08, 2005 - 01:36 PM
Whats your weight ?
  • alfa
Posted July 08, 2005 - 01:39 PM
190lbs
  • DesertWR
Posted July 08, 2005 - 02:02 PM
Put a 5.6 rear spring and revalve your front forks with racetech gold valves :)
  • hotrunnin-05wr450
Posted July 08, 2005 - 03:01 PM
lose 10 lbs!!! :) :) :D ..try weighin 250lbs, theres something to complain about! :D ..i think its recetech that has a chart for ur weight on there website, check it out.
  • copper10
Posted July 08, 2005 - 08:52 PM
I had the same problem with my 2005 wr450, i also weigh 190. Sent my suspension in to rg3 they put a 5.6 spring on and revalved forks and shock with good results. I ride baja and desert.
  • Matty05
Posted July 08, 2005 - 09:37 PM
I put .50 springs in the forks and 6.0 spring on the shock for my 110kg ass.
The shock is good but something is wrong with my fork dampening.
When I get time I will send my suspension away to get valved and my girl's
away to get lowered as well. I should have done this to start with.
