Removing the Grey wire on a 05 WR450F.
10 replies to this topic
  • Al Curtis
Posted July 07, 2005 - 01:27 PM
I bought an 05 WR450F a couple of weeks ago, WOW, Big change from an (nobody laugh now) 83 XR350. I had the dealer take out the throttle stop and change the pipe tip. I will be re-jetting and removing the AIS. Can anyone tell me how removing the Grey wire will affect the performance, I know it changes the timing to that of the YZ but, is it going to be noticeable? Can I change it back or does it change it permanently.
  • WGP
Posted July 07, 2005 - 02:23 PM
Do a search, us who bought this bike right when it came out already busted this topic :)
  • byggd
Posted July 07, 2005 - 03:37 PM
Below 1/2 throttle you won't notice a difference IMO. After 1/2 throttle the TPS sends a signal and the timing stops advancing and retards some (15 degrees I think I read). Some people put a toggle switch on the grey wire so they can switch between wr and yz timing but from what I understand you have to shut the bike off for it to take effect.
  • Texas4play
Posted July 07, 2005 - 03:52 PM
I unplugged mine and never looked back ...
  • Dodjy
Posted July 07, 2005 - 06:44 PM
Does anyone know if you can do this mod on the Aussie bikes?
  • Al Curtis
Posted July 07, 2005 - 07:24 PM
Thanks guys, I'll try it, and I like the toggle switch idea.
  • Al Curtis
Posted July 07, 2005 - 07:41 PM
Sorry I'm new at this,how do I do a search on passed talks?
  • Matty05
Posted July 08, 2005 - 02:25 AM
Only '05 450's I think from what I have read. I have did the mod and I don't know if it has did anything. :)
  • byggd
Posted July 08, 2005 - 04:19 AM
Go all the way to the top right and click search. You can search by key phrase, room, date etc :)
  • Al Curtis
Posted July 08, 2005 - 06:12 AM
Thanks.
  • alfa
Posted July 08, 2005 - 01:38 PM
You will notice a difference in the higher rpm range. Yes you can put it back. I read somewhere that you should not pull the grey wire out of it's boot beacuse it will mess up the water proff seal for the other wires on that connector. I cut the wire about half way so I can splice it back together it I wanted to. But I don't.
