XRs only exaust
7 replies to this topic
  • goblin127
Posted July 05, 2005 - 08:14 PM
Have had my comlete xrs only exaust on the bike for about a week now .Its louder than I was told it would be , but I am quit happy with it . Monting was better than some pipes I have used .Sounds great now that I am getting used to it. I did put the largest main jet I could find in it .165 dyna jet that came with the kit that I started with. Quality seems very good . I will clean up the weld s this winter.
  • SONODROOPY
Posted July 06, 2005 - 01:03 PM
How much was it? :) :)
  • BWB63
Posted July 06, 2005 - 03:00 PM
Do you have the spark arrestor screen in it?? What elevation are you? That is a way lean jetting for anything close to sea level.
  • goblin127
Posted July 07, 2005 - 05:07 AM
Cost was 530 to my door. Yes the spark arrester screen is in it. The jetting is a 55 pilot and 165 dyna main .No poping on decell. Just about 140 feet above sea level. I tried to find a larger pilot but as yet no luck. What jetting would you recommend? BWB63 Hay nice slide show you put on THANX!
  • goblin127
Posted July 07, 2005 - 05:10 AM
Oh yea this seems to be there new oval ended pipe.They told me I wouldnt have to rejet can you believe it.
  • Mikie1
Posted July 07, 2005 - 05:24 AM
Hmmm... Is this the one that's supposed to be a close copy of the pipe Pro Circuit makes for Team Honda? Tapered head pipes, megaphone center section going into the silencer?
  • goblin127
Posted July 07, 2005 - 08:15 PM
Idont no about it being a copy of the procir. The muff.is oval withscreen the header is not tapered,two into one into muff.The diameter of the header pipes are larger than stock I know thats a given. Any body want to recommend jetting size? As I said before I am running 55 pilot 165 dyno jet slide drilled dyno jet spring snorkell off smog gone. any one thanx : :
  • ghoti
Posted July 08, 2005 - 04:42 AM
Do you have a "L" with the CV carb. If so The 165 DJ main is something like a 155 Keihein(sp). Go with an original Keihein and you can go much larger.
  • Hot  29 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
  • Hot  186 replies
Washington
  • Hot  32 replies
