rear axle seized
2 replies to this topic
  • madmud
Posted July 05, 2005 - 06:26 PM
Got a mel of a hess here. In going to remove the rear wheel (to lube & grease the swingarm) I discovered the rear axle seized to the chain side wheel bearing. After spraying plenty of deep creep in there ,leaving it sit overnite, and using a 1/2" impact to try to jar it loose, no luck. When rapped with a 4x4 block and a large hammer the bearing comes out appx. 1/4" along w/ the axle and thats all the movement I can get. Any suggestions? looks like the sawzall is the next step
  • Gadsen
Posted July 05, 2005 - 07:51 PM
Well, Sawzall might be the answer! Man, I love my sawzall. How did we ever get by before the sawzall :)
  • jbrooks26
Posted July 05, 2005 - 08:05 PM
Might try a little heat and get a bigger hammer. Going to have to replace the bearing anyway, may as well try to save the axle. Just heat the bearing if possible. Just my 2c.
Josh
