xr650l susp. ?
4 replies to this topic
  • goblin127
Posted July 05, 2005 - 06:13 AM
I was going up a long fairly steap,gravel road and the rear end of the bike seemed to have a weird hop to the rear susp. Just doesnt feel right. the susp is dialed up preety stiff is this the problem?
  • roadcam
Posted July 05, 2005 - 06:54 AM
story has it our XR650L is sprung from the factory for a 160-pound rider ... unless you're real light, I doubt if you're set up too stiff ... us bigger guys run the clickers up as hard as they'll go, and still too soft without aftermarket springs
  • easton_kooka
Posted July 05, 2005 - 08:56 AM
This is a fairly common sensation of gravel, because it is a strange surface. Lots of grip but yet very little, so it's easy to get minor non-constant spinning of the rear wheel. This is especially the case when you're pulling fairly low RPMs. This slip/grip would then feed back through the suspension causing you to feel a hopping sensation as the suspension compressed and extended from chain torque. And since suspension is fun, this hopping makes the slip/grip oscillations worse and the hop sensation gets larger.
You can check if this is the case by seeing how the oscillations change at different RPMs on the same hill.
  • goblin127
Posted July 05, 2005 - 07:55 PM
Thanx easton that seems to some it up very well. I will be hiten that hill again soon.
  • Rover31
Posted July 05, 2005 - 09:37 PM
have you set your sag 1st?
  • Hot  29 replies
  • 9 replies
  • 3 replies
  • 17 replies
