Seal saver install
7 replies to this topic
  • beavis2732
Posted July 02, 2005 - 06:42 AM
when installing sealsavers am I supposed to remove the fork guard guides from the upper fork tube?? I have not recieved them yet but was just wondering beforehand for once. can I mount the sealsaver under the guide clamp? will it make a difference if it is removed completely? I'm not sure if removing the guide will affect the performance of the fork guards.
Thanks for the help
Beavis
  • Fryboy
Posted July 02, 2005 - 11:49 AM
Hey Beavis,
Yes you mount them under the upper fork guard clamp. It is a lot easier then you think !
Loosen top and lower triple clamps
Remove your front wheel
Slide the forks down past both clamps
Slide on seal savers
Put on fork guard clamp
Slide back into Triples
Tighten up everything and forget about your seals ever going bad again :)
  • mtrablue
Posted July 03, 2005 - 05:46 AM
you'll probably need longer screws.
  • Dan_Lorenze
Posted July 03, 2005 - 06:50 AM
I installed mine by sliding both fork tubes out of the clamps at the same time, keeping the wheel attached. :) It wasn't pretty but I got 'em on. :)
  • xcracer123
Posted July 03, 2005 - 07:01 PM
I did the same but used the help of a friend to reinstall the forks in to the triple tree. Pretty straight forward that way.
  • Dan_Lorenze
Posted July 04, 2005 - 06:44 AM
What I was missing was "a friend" to help, the bike was all over the place, I was lookin dumb.. :) I was just so stubborn not to take off the front wheel.. (maybe lazy's a better word for it) :)
  • trickwarrior
Posted July 04, 2005 - 10:44 AM
I installed mine from the bottom with the wheel off. I put them on like 4 monthes ago and have had no problems. I talked to a guy at seal saver and he recommended that I remove the top guard holders and just use a zip-ty on the top. It has worked fine for me that way and no new screws are needed. :)
  • Matty05
Posted July 04, 2005 - 10:57 PM
:) :D :D Thats what I did!
