Help...going riding tomorrow but bike is backfiring!
8 replies to this topic
  • bigroj
Posted July 01, 2005 - 05:53 PM
Can someone please tell me why a bike would backfire? I have a 2004 YZ450F with about 5 total hours on it. It just started to backfire and I'm not sure why a bike would do this...any help would be greatly appreciated. :)
  • Hick
Posted July 01, 2005 - 07:53 PM
Just started???
How does it run otherwise?
What were you doing, or how did you "make" it backfire?
Does it do it w/ the throttle off, on, low rpms, high rpms, in gear while riding or just on the stand in the garage?
Sorry for all questions and no answers but...
  • David37
Posted July 01, 2005 - 07:59 PM
We need more information to help you with your backfire problem. Did you recently put a new pipe on or recently work on your carb., install a clean air filter? Like Hick asked when does the backfire happen?
  • bigroj
Posted July 01, 2005 - 10:40 PM
Sorry guys....
It backfires when I let off the throttle (in all gears). And yes, it just started happening. This bike is bone stock, no new parts at all. I have not tuned anything on it since I bought it, including the jetting/carb. I am totally baffled by this...
  • big t
Posted July 01, 2005 - 10:52 PM
Check your hot start lever. Make sure it is adjusted right and not sticking.
  • bigroj
Posted July 01, 2005 - 11:01 PM
Will do, thanks!
  • centermass
Posted July 02, 2005 - 03:48 PM
i'm not sure what the exact reason for your backfiring problem is .. but it could be a few things. gas turned off or not fully in the on position ,mot likely this will cause the bike to backfire or pop. it's probably the jetting.. check those things out and good luck .
  • ovrrdrive
Posted July 02, 2005 - 10:59 PM
I'll almost guarantee it's a problem with the hotstart...
Pull the plunger and lubricate it and then reinstall it.
I screwed mine up once and got the same problem you describe. I reseated it and all was fine. :)
  • bigroj
Posted July 03, 2005 - 10:48 PM
Yep...it was the hotstart lever. I had to hold the housing and push the hotstart lever all the way back before it would shut the valve. When I released it after using it, the lever would go back up but underneath the rubber cover, the housing would move but not the cable inside of it. I hope that makes sense. Once I lube it up it's been great.
Man I love this site.
Thanks everyone!! :) :) :D
  • Hot  28 replies
  • Hot  33 replies
  • Hot  36 replies
