Handling problem due to low oil level in forks?
4 replies to this topic
  • per_s
Posted July 01, 2005 - 03:26 AM
Hi,
will a difference in oil level make a noticeable difference? I guess handling or such things might be a problem...
Give me your input please.
/P :)
Posted July 01, 2005 - 07:06 AM
Late model Yamahas before the '05 models are a little fussy about oil level, actually. The fork is a closed space that changes volume as it compresses and extends. The fork oil, being a fluid, will not compress, so the air in the space above the oil has to compress to allow the fork to go all the way to the bottom. The air, then becomes a kind of auxiliary spring. If the oil level is set too high, the air is compressed too much, and the fork acts harsh and stiff. If the oil level is lowered, the fork feels smoother, but the Kayaba fork will start to bottom out too easily if the oil level is lowered even a little too low.
Sub tanks, the small tanks attached to the fork caps with small hoses help this problem by increasing the air volume in the top of the fork, which allows running oil at high levels without the harshness.
  • per_s
Posted July 01, 2005 - 08:17 AM
OK, and if I have different amount in one of the tubes? will I have a anstable handling?
/Per
  • Dolce_Grappa
Posted July 01, 2005 - 09:01 AM
Yes, it will cause unstable handling. You'll be prone to headshake over breaking bumps and hard impacts.
  • mxaction
Posted July 01, 2005 - 10:22 AM
This is a good buy. Try here: www.enzoracing.com
It does require some minor maintnance though.
  • Hot  79 replies
Motocross
  • Hot  491 replies
  • Hot  47 replies
  • Hot  33 replies
