650r Jetting
2 replies to this topic
  • WFODEZ
Posted June 30, 2005 - 12:46 PM
Is It Possible To Change The Pilot As You Can The Main Without Removing Tank, Seat Etc?
  • DGXR
Posted June 30, 2005 - 12:54 PM
I think you can. After removing the bowl, you will probably need a flashlight to see up into the carb body and a tiny screwdriver to reach the pilot because it's an awkward angle. Also, it should not be too tough to just remove the carbs so you have the best access.
  • frankstr
Posted June 30, 2005 - 01:07 PM
Just take your tank off, Loosen the rubber boot screw clamps and spin the carb enough to remove the bowl..No need to remove carb to change pilot jet..
I do believe you need to remove carb bowl......
  • Hot  60 replies
  • Hot  35 replies
Honda XR650L 2016
  • 0 reviews
  • 22 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
