'98 400 head different than '00 426?
9 replies to this topic
  • sharpmarble
Posted June 30, 2005 - 09:20 AM
Does anyone know how these heads are different? (different P/N) I need a head for my 426, but the one for the 400 is cheaper.... :)
Thanks
  • bushy
Posted June 30, 2005 - 09:25 AM
I dont think they are different.
  • PumpkinHumper
Posted June 30, 2005 - 11:18 AM
I would guess that they are the same also.
  • Flash319
Posted June 30, 2005 - 11:20 AM
I would say that they are probebly different because of the Ti valves in the 426. Or was their a year of 426 with steel....?????
  • sharpmarble
Posted June 30, 2005 - 02:25 PM
Wouldn't the steel valves be preferable? I know they weigh more, but you wouldn't have to worry about snapping one....(not that it's a common thing!!)
  • Pincushion
Posted June 30, 2005 - 03:00 PM
2000 has steel valves, same as the 400's. If the numbers dont match then I would assume there is a difference.
If it were a spoke then I'd consider, but this is the head.
  • sharpmarble
Posted July 01, 2005 - 05:57 AM
Anyone know for sure???? Hick, Gray, Indy??? Anyone?
  • mxaction
Posted July 01, 2005 - 10:35 AM
If the numbers dont match there is a difference.
  • Hick
Posted July 01, 2005 - 07:32 PM
There is no difference that I know of, but I'm not certain they are identical. I am sure enough that I would not hesitate to swap one for the other on my own bike.
This is not necessarily true, sometimes the PN will change to signify a different model or different supplier despite the part being the same for all practical purposes.
  • lightestYZF
Posted July 03, 2005 - 06:51 AM
There is at least one major difference in the 98/99 head versus the 00-02.
In 98/99 the hot start was separate from the carb. The intake between the carb and intake valves has a port or tube cast in that the remote hot start connects to. Using a 98/99 head on a 00 to 02 would require blocking that off or installing a second hot start like the one ty davis sells.
  • 0 replies
  • Hot  36 replies
  • Hot  28 replies
  • Hot  50 replies
