Just purchased 95 XR 600
3 replies to this topic
  • SONODROOPY
Posted June 29, 2005 - 01:18 PM
Just purchase a 1995 XR 600. New to ThumperTalk. Want some advice.
How should my carb be set up?
Bike contains K&N filter, Husky exhaust?(thumps low, loud reved), 13t front sprocket 48t rear. Otherwise bike is stock. Ride between 5000 and 10000 ft.
I ride trails in 1st thru 3rd.
Your help is appreciated
P.S. The bike hesitates sometimes in 1st when you get on it.
  • justicedone
Posted June 29, 2005 - 09:39 PM
Sounds like you need to jet the carb for your altitude and drill the slide. Heres some info thanks to Big Dave...
http://www.4strokes....xr650lcarbmods/
  • justicedone
Posted June 29, 2005 - 09:40 PM
Sorry I cant help with jet advise, I run a 55/158 but run at Sea level to 5000ft.
  • XR6's_rule
Posted June 30, 2005 - 03:48 AM
I run this jetting at 100m (300 ft) to 400m (1200 ft) and it works great-
155 main jet- 1 size richer than stock
62 pilot jet- stock
airscrew 2.5 turns out- stock 2 turns out
needle 3rd (middle) clip position- stock
float height 14.5mm- stock
*You could use this jetting as a starting point and if needs be, got one size leaner (smaller) with the jets at a time.
